should be able to swap in a 350 with out to much greif if its a throtle body motor you should be able to swap ecm a coupl of sensors and prolly the throtle body (i dont think they are the same and even if the throtle body is the same the injectors should be different)if your going with a used salvage yard motor you can prolly get the ecm and and the throtle body should come with a complete motor thats about the cheapest way out
