1991 mazda b2600 not running right - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-05-2012, 08:45 AM
Ok so I aquired this "mini" truck from a junk yard near here for super cheap. I drove it for awhile but now it will start but dies imediately unless you play with the throttle. Once it levels out it runs fine %50 of the time. It is fuel injected (did not know these had that factory option) and I have already checked fuel pump, fuel filter, spark plugs, spark plug wires, and relays...what could be wrong besides it being a junk yard dog?
Old 07-05-2012, 12:59 PM
BOBCRMAN@aol.com's Avatar
Loose wire or air/fuel sensor going bad. I had one in a delivery truck. The sensor was loose in the air intake housing near the front and would do the same thing..
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
revone (07-05-2012)
Old 07-05-2012, 03:01 PM
I was finaly able to narrow it down..going from sensor to sensor and found that mazda is really proud of their mass air flow sensors...400 bucks...guess what...yep thats my problem after unplugging it the truck runs better but still needs that part to run correctly
Old 07-05-2012, 07:25 PM
You will find the sensor is the same as Ford Ranger.. Get one at the bone yard for a couple of bucks!!
revone (07-05-2012)
Old 07-05-2012, 07:51 PM
I found that ebay is a good place to find new parts cheep and if I have to I will go find one from the junk yard
Mazda Miata running gear oldpackrat Hotrodding Basics 5 02-04-2007 08:30 PM
1991 olds will not stay running 68novafan Engine 4 12-11-2006 08:30 PM
how do i perform a body drop on my 1986 & 1991 mazda trucks lowrider12 Body - Exterior 2 08-26-2006 04:18 PM
running amp wires in a 1991 chevy caprice bxallday Electrical 5 04-05-2006 12:38 AM
Mazda B2600 transmission removal help/ chevcamz28newbie Transmission - Rearend 1 11-06-2003 07:28 PM
