1991 olds 88 coil pack check - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2006, 10:27 PM
Well I ran across more info on my vibs and it was suggested that coil packs can cause a low rpm missfire.........makeing one think the vibs were in the converter or tranny........how would I check the coil pack out completely..................the guy said he was running out to do a ohm check on his leads and coil pack............my VERY detaled haynes manual doesnt have this check or the specs other than the plug wire resistance should be less than 30,000 ohms......man it would be really nice if it was the coil pack
Old 09-15-2006, 11:42 AM
sedan delivery's Avatar
coil test
TESTING
Remove the ignition coil(s).
Using an ohmmeter, check the resistance between the primary terminals on the underside of the coil. The resistance should be 0.50-0.90 ohms.
Check the resistance between the secondary terminals. It should be 5,000-8,000 ohms.
If the coil failed either test, replace the coil.
Old 09-15-2006, 11:46 AM
coil pack
REMOVAL & INSTALLATION
3.8L (VIN 3) Engine
Disconnect the negative battery cable.
Tag and disconnect the spark plug wires.
Unfasten the ignition coil(s) attaching bolts, then remove the ignition coil from the module.
To install:
Install the coil(s) and attaching bolts.
Connect the spark plug wires.
Connect the negative battery cable.
3.8L (VIN C) Engine
See Figures 1, 2, 3 and 4
Fig. 1: Labeling the wires before disconnecting them from the coil helps assure correct reconnection
Fig. 2: After removing the wires, you can see the 5 Torx® retaining screws
Remove the 5 retaining screws, or Torx® screws, as applicable, securing the coil to the ignition module.
Fig. 3: Unfasten the mounting screws, then lift the coil up from the ignition module and label the connectors
Tilt the coil assembly back and unplug the coil-to-module connectors.
Fig. 4: After unplugging the connectors, you can remove the ignition coil pack from the module
Remove the coil assembly.
Although the 3.8L engine's Type I coil pack will physically fit, the position of the number 1 coil, as noted on the coil pack, is in a different location; coil towers No. 1 and 4 on the 3800 engine are closest to the module connector.
To install:
Fit the coil assembly into position and attach the connectors.
Install the retaining screws, or Torx® screws, as applicable, and tighten to 26 inch lbs. (3 Nm).
Connect the spark plug wires, as tagged during removal.
Reconnect the negative battery cable.
3.8L (VIN L, 1 and K) Engine
See Figures 5 and 6
Remove the 2 retaining screws securing the coil to the ignition module.
Fig. 5: In 1992, there were 2 different ignition coils used: a Type I, as shown here ...
Fig. 6: ... and a Type II, shown here. Later model vehicles use the Type II
To install:
Fit the coil assembly to the ignition module.
Install the retaining screws and tighten them to 40 inch lbs. (4-5 Nm).
Attach the spark plug wires, as tagged during removal.
The material provided in the Repair Guides is under license from Delmar Publishers. Any part of these publications may not be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying, recording, storage in an information retrieval system, or otherwise, without the Written Permission of the publisher. Any unauthorized commercial use, resale or mailing list database development, utilization or application is also prohibited.
© 2001-2006 AutoZone, Inc. All Rights Reserved.
Old 09-15-2006, 01:24 PM
interesting...........thats what I needed the ohm value and how to do it......thanks again................I wonder if autozone would test it for me too...........I have the old one which REALLY does missfire under a revv, and the junkyard one that seems to work.....I had alternators tested at one of the local zones and they said it was bad.....so I had them test one right out of the box.........and the machine told them it was bad too!!!!!
Old 09-15-2006, 01:37 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
Fumplet,
You will never get this thing fixed, unless you stop jumping from possible cause to possible cause.
The last thread you said the vibration would go away by unlocking the lock up converter, now you are onto the coil packs. What gives??? If you find a problem, you must fix that first before trying to find other causes.
If not you are just chasing your tail.
Steve
Old 09-16-2006, 12:57 AM
oh yes I know........this thread was posted a while ago.....wont really do anything other than casually check things........wouldnt hurt to check coil pack just to see.................still waiting for money to replace struts
Old 09-16-2006, 08:12 AM
1931 steve's Avatar
Wiki Edits: 4
Struts!!! Struts have nothing to do with the lock up converter
Steve
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
pair of 62 olds super 88 w/394s zamaro Engine 0 04-03-2004 08:16 PM
94 olds 88 transmission - overdrive litt810 Transmission - Rearend 3 08-09-2003 03:20 PM
2002 Durango Vs 1990 Olds 88..i did it...... Rubberman2003 Hotrodders' Lounge 4 06-24-2003 03:09 AM
disc brakes on 62 olds supper 88 fly82_99 Suspension - Brakes - Steering 0 05-15-2002 11:03 PM
