1991 olds 88 heavy duty air conditioning fan polarity and position - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2006, 08:22 AM
Hi people......I bought the heavy duty a/c fan that sucks air through the other half of the radiator and condenser........hoping this addition will help my a/c cool better....especially at stop signs.......problem is the radiator in the car at the junk yard was an at least an inch or more longer and I didnt notice it........so I either need to buy that radiator or mount the fan farther away from the radiator so the blade wont hit the radiator tank or mount it up front on the condenser side..........If I go the condenser side........has anyone reversed the polarity of a fan to get it to spin backwards?
Old 08-20-2006, 06:16 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
If the motor is a standard DC motor, and is not polarity protected By a Diode or Electrolytic capacitor, then simply reversing the power and ground leads will allow it to run backwards..
BE SURE , before you do that the Black wire or ground Does not Also have continuity to the Motor Body..or reversing will just short out.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 08-30-2006, 11:35 AM
Hello Doc..........do you have the schematic of how the extra a c fan is supposed to be wired?...........I pulled it out of a 1993 pontiac bonnieville but olds should be the same......mine does not have this extra wiring and I want to add it
Old 08-30-2006, 02:54 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Here is the 93 BV Schematic for the fans:
Both low and high..
Doc
Innovations
