1991 olds 88 royale idle miss - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2010, 09:28 PM
Hello I have the 1991 royale and just put a timing chain, cam gear magnet, water pump, ect on the car to get rid of the code 41 it had. Well, no light now but the car runs with a sporadic miss at idle when warm. I was wondering if theres scan software that I can put on my laptop to help diagnose this. Winaldl doesnt work on this car. and tuning pro is not for me since I dont know how to program bin files that it needs. I really dont want to take the car to a shop just so they can charge me bull**** fees and say they found nothing. been there done that. Really hoping somebody here knows of software that will allow me to see whats going on in the engine real time. Cars got 140,ooo on it now. 3800 engine. Sprayed plug wires with no noticable results. Oh yeah, already tried to sign up on oldsmobile forum...its deader than roadkill. Nobodys posted over in the eighty eight section for over 30 days...so it told me.
Old 01-31-2010, 08:40 AM
sqzbox's Avatar
My pipes are my music
Did you change the plugs?
A friend of mine has the same problem and found a leaky tube going to the EGR valve. He had changed the plugs and it ran great for two weeks and then started running like crap again. After finding the leak to the EGR valve and fixing it, he checked the plugs again and they were ugly! All fouled up with huge amounts of deposits on them. He changed the plugs again and so far it's running good.
I have a 3.1 (3.8's little brother) in my GP and it has had a little shake in it at idle in N since the day I bought it new. In gear, stoped, it runs smooth and can't tell it's even running. I've got 103K on it now and it still get's 30+ MPG on the hwy.
Old 01-31-2010, 09:29 AM
Hippie's Avatar
Last journal entry: HEI comparison.
Most "FLAPS" (Friendly Local Auto Parts Store) will run a scan for you free of charge.
Old 01-31-2010, 04:49 PM
T-bucket23's Avatar
Wiki Edits: 26
Did it do it before you did the work. If not I would bet the chain is off one tooth. This can really confuse the ECM as the cam and crank signals will never be synched up. As someone else mentioned the EGR could be hanging.
Good diagnostic equipment cost a lot of money and the skills to use it are also very valuable. Just fining a scanner software that will work with your car does not guaranty you will even recognize the problem. An experienced tech will know what the signals should look like and most likely has seen your issue before.
Chet
Old 02-04-2010, 11:35 PM
yes it had an occasional miss before but now its slightly worse. As for getting the timing chain off a tooth. Nope. Eyeballed that sucker many times before putting cover back on. It doesnt miss when cold. Gotta run it and get it warm. It does have a small exhaust leak but its not loud at all. Donut gasket or pipe somewhere. Maybe the leak is making the O2 indicate a lean condition? As far as the chain goes, I just lined up the dots as close as possable. If it was off a tooth, Id know. Thats pretty obvious when it is.....I hope
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Carb tuning issues - 750 speed demon lightningcow Engine 48 07-01-2009 07:32 AM
DARK brown--BLACK plugs SBC Joshua Lee Engine 128 02-03-2008 09:12 AM
94 olds 88 transmission - overdrive litt810 Transmission - Rearend 3 08-09-2003 03:20 PM
disc brakes on 62 olds supper 88 fly82_99 Suspension - Brakes - Steering 0 05-15-2002 11:03 PM
