Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1991 olds eighty eight royale eats right front brake pads
Old 11-17-2012, 08:02 PM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
Or check your calipers, if the passenger side caliper is sticking (the calipers have pistons that can stick if rusted, misaligned or bad seals), you can check the piston by taking a C clamp and try to push the piston in the caliper, if it doesn't go back fairly easily, it's time to replace them, replace both left and right calipers for even brake pressure in the future.
Hope this helps.
Ray
