Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1991 olds eighty eight royale eats right front brake pads
Old 11-19-2012, 04:14 PM
MouseFink MouseFink is online now
Three months ago, the squeaker on the outboard pad of my RH floating front brake caliper began squeaking prematurely. I examined the pads and discovered uneven brake pad wear on the outboard pad of the RH caliper on my '91 S10 Blazer 4x4. I replaced the AC Delco ceramic pads with Bendix ceramic pads, replaced all the slider pins, and replaced all the o-rings in each of the calipers. The o-rings align the slider pins that the outboard caliper slides on as it compresses into the brake rotor. I also lubed the caliper contact points and o-rings with Permatex #20353 brake lube. I checked the pads yesterday, and I saw no sign of uneven brake pad wear after about 1,000 miles of stop and go driving.
If the o-rings in the calipers are dry, the outboard caliper and pad will not slide evenly and apply equal brake pressure to the rotor. The pad may wear on a taper and permit the squeaker to contact the rotor prematurely. Your rebuilt calipers should have new o-rings but they need to be lubed before the calipers are installed with the proper high temperature silicone lubricant.
The Following User Says Thank You to MouseFink For This Useful Post:
LATECH (11-19-2012)
