1991 oldsmobile 88 eats battery after a week or so - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-26-2007, 05:02 PM
docvette's Avatar
Wiki Edits: 12
Originally Posted by fumplet
....they said to crank up the charge to get the battery to work.....
GM batterys were designed a little different and could handle the boost.............
or were they just trying to shorten the life of the battery but get it working again and avoid warrenty claim
Doc here,
Yes, and Yes/No..
Sounds like you got the "Service Writer Manager Propaganda" ...(the same stuff they tell all "Stupid consumers" (they believe) when you have a plug misfiring...."it's a valve..but we can't tell until we get the head off.." may have to go even deeper.. "Throw some plugs in the day~um thing and be done with it for $150..instead of the estimated , and they will meet it..$3500 and a week downtime, Oh..and a new set of plugs")
You may tell..I don't like Nor Do I trust dealerships at all..
Yes..Because it CAN be charged..and it does get them out of a warranty replacement..
And Yes/No..Because When a battery goes that flat..(and I mean it won't run a test lamp..) that is the only way to get it to respond..
And..H2SO4 Battery's haven't changed , with the possible exception of casing choices, or plate thickness, over the last 200 years chemically, and structurally when they were in Lydon (Sp?) jars..more Bull for the masses..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
  #17 (permalink)
Old 04-17-2011, 10:03 PM
Just posting this for the masses as an FYI. Still have the car. Hasnt eaten batterys since I disconnected the dam draining issue. GM cars in the oh, 1970s on up through the 1980s???, had the antenna built into the front windshields. Sometime in the 1980s they got rid of that. Most chevys just went back to the standard whip antenna. However, your upper lines of gm cars gave people a POWER ANTENNA. Well, my antenna still works, goes up and down when the ignition is switched on and off. Much to my suprize, when I was rooting around in trunk, I touched the motor of said antenna. The dam thing was hot!. Even though it worked, it wouldnt shut off, after retracting. This didnt happen all the time though. Sometimes it would go for months with out killing the battery.
Solution, disconnected the motor to the antenna and havnt lost a battery since.
  #18 (permalink)
Old 04-17-2011, 11:27 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Looooong time to follow up, better late then never.
Good thing it didn't set the car on fire.
  #19 (permalink)
Old 04-18-2011, 04:06 AM
EOD Guy's Avatar
Have to put that one in the old brain bucket file cab.
1991 olds 88 heavy duty air conditioning fan polarity and position fumplet Electrical 3 08-30-2006 02:54 PM
1991 olds 88 front windows roll up very slowly fumplet Electrical 3 08-24-2006 01:10 PM
what kind of window track grease should I use for a 1991 olds 88 fumplet Interior 2 08-24-2006 10:29 AM
1991 olds 88 tentioner rides back and forth fumplet Engine 1 08-21-2006 02:14 PM
1991 olds 88 radiator tranny line kinked? fumplet Engine 1 08-20-2006 11:07 AM
