1991 Pontiac Firebird knock sensor location 5.0. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2012, 06:25 PM
31 five window
Last journal entry: grill and rear end
Where is the knock sensor on a 1991 Pontiac Firebird 5.0 TBI engine.I think it is on the passenger side right above oil pan rail but Autozone says it is in the head.Who is correct? Thanks.
Old 05-02-2012, 06:59 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Autozone is wrong. You are correct, it is next to the pan rail,closest to where the knocking would occur. L
Fact is stranger than Fiction
Old 05-02-2012, 09:39 PM
31 five window
Thanks. It is where the block drain plug is on the opposite side.
Old 05-03-2012, 06:09 PM
LATECH's Avatar
Yubber, that is what you are looking for.
Be sure the engine is cool when you remove it, as it will have coolant behind it.
Old 05-03-2012, 09:26 PM
31 five window
I thank you all.I have the problem fixed. I don't work much on newer vehicles so sometimes I am unsure.I was sure I knew where it was and that there was coolant behind it. I was helping a friend with less experience than me put the engine in a 1948 Ford truck.When we started hooking up the wires we found a broken temp sensor in the passenger side head.Long story short,don't trust the guy looking on the computer at autozone.
1991 pontiac firebird 91firebird Hotrodding Basics 2 01-23-2011 12:49 PM
Knock sensor location 91 Crown Vic 351? macx Engine 6 07-16-2006 01:24 AM
knock sensor 88chevy Engine 8 06-18-2006 11:56 PM
1991 pontiac firebird DARKMAN89 Electrical 1 01-23-2006 09:21 PM
knock sensor jo5hi3 Engine 10 10-29-2004 02:00 PM
