1991 rear end id - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2005, 12:52 AM
1991 rear end id
i have a 1991 rs camero with a 5 speed and a stock 10 bolt rearend can anyone tell me, or how to find out what kind of rear end it is ,7.5,8.5,8.8?? and the ratio?? im running a 350 with modifications what would be a good street/strip gear ratio?
Old 09-16-2005, 09:25 AM
The best way to tell what ratio you have is to pop the cover off and read the #'s on the ring gear. Most likely the oil in the rear end hasen't been changed in a long while anyways.
Old 09-16-2005, 09:47 AM
BooWFO's Avatar
If it's the original should be the 7 5/8" 10 bolt. Also stock gear should be a 3.08 for a 5spd v8 RS. if it's a v6 think it was 3.42 for a 5spd. Autos were v8 2.73 v6 3.23. Not sure but I think there may have been some g92's which would've been a 3.42.
Hope it helps.
Old 09-16-2005, 11:22 AM
larryblack's Avatar
Certified Lead Foot
With a 24-26 inch tire use 3.42 gears. If you have or go to 3.73 or 4.10 go to 27-28 inch tall tire.
If your RS was V8 from the factory you have the 7-5/8 with 28 spline axles.
Old 09-20-2005, 02:49 PM
Rev It Loud, Drive It Proud!
Look at the RPO sticker
Thump Thump in rear end?? HotRodMan Suspension - Brakes - Steering 7 01-24-2007 06:09 PM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 05:32 AM
Rear End Change black66 Transmission - Rearend 4 01-28-2004 09:21 AM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 06:05 PM
Ford 7.5" Rear End Traction-Loc Install nightrain_rod Transmission - Rearend 2 12-30-2003 06:38 PM
