1991 S10 with 2001 LS1 & 700r4, Trans has no shifts - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2011, 04:51 PM
i have a 1991 s10 i put a 2001 ls1 in it with a 700r4 the motor has lil work done like head work 612 615 cam eagel rods forged pistons my problem is the trans want shift out of first gear ive ried verything new governor new tv cable had it adjusted i pulled tv valve piston it wasnt stuck the governor was messed up the teeth was stripped of the gear in dont know what else to do besides pull it out and put a 350 turbo behind it and junk the 700r4. please any suggestions before i do i tried everything
Old 03-17-2011, 06:52 PM
SSedan64's Avatar
If the teeth on the Gov were stripped it's not going to shift.
You need to check the Gov bore in the Trans case to see why the teeth stripped, then replace the gear.
Old 03-17-2011, 07:01 PM
Trans
I did I pulled it out and roll pin was to far out and was touching the case. took the tail housing off and cleaned it out and put a new one in it and replaced tv cable and everything dont know what else to do besides pull it out amd have it looked at. The fuy I bought it from said it was built but couldnt get it to shift eithier I didnt think it was anything major but guess I was wrong
Old 03-17-2011, 07:02 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
The Governor when you replaced the gear did you check to see if the valve moved freely? What maybe happening is that the output shaft bushing is getting weak and it allows enough movement of the output shaft to wear the governor gear or break it off. What did you find in the pan? if the pan was contaminated with brass shavings or metal shavings or shavings from anything inside your transmission like a planetary gear or maybe a worn pump.
Rich
The link will yield more information.
700r4 wont shift out of first gear
Old 03-17-2011, 07:06 PM
Trans
Yah everything was clean no shavings or anything no slaxk in bushings or anything. I pulled the new one out it srill look good not stuck or anything im puzzeled
Old 03-17-2011, 07:21 PM
Then you'll need to go back to the TV. remove the valve body (don't forget to chock the wheels before pulling the VB) and loosen the TV, working it in and out. If you have to do this a 700jr. kit is great to install because you get a no stick TV with it.
Rich
Old 03-17-2011, 07:38 PM
T
I just pulled the vb down and it was clean and the tv wasnt stuck it had a spring behind it to prevent sticking I guess ill have to pull it out and take it somewhere and have it looked at im puzzeled im usally good on these but not this one might just go with a 350 turbo but kinda want overdrive
Old 03-17-2011, 07:40 PM
T
Thank u for the help. Anything u can think of please let me know ill try anything before pulling it its a pain in the but
Old 03-17-2011, 07:57 PM
with the price of fuel heading out of sight I'd be hard pressed to go with a non OD unit. At the moment I'm using an E350 mini bus w/6.9 diesel, I wish it had two OD units in it.
Rich
Old 03-17-2011, 08:12 PM
On the TV on older 700's there will be an aluminum sleeve the TV rides in. The valve body castings #'s 2264 does and i think 4256 does also. It's better to replace this valve body with a 4442 casting.
Rich
Old 03-18-2011, 09:32 AM
T
I guess im gonna pull it out and take it some where I have tried everything I can think of I bet ive pulles the valve body a billion times I can do it in my sleep dont know what else to do but thanks for the help everyone. Im gonna try one one thing on passenger side of tranny the second gear plunger gonna see if its stuck also and the screens in tranny for governor and tourqconverter
Old 03-20-2011, 06:29 PM
trans
i finally got my 700r4 to shift i had to completly disassembel the trans like valve body and evrything. its shifting late do i need to losen my cabel or tighten it.
Old 03-20-2011, 06:53 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
91lss10.... I merged your new thread to the old thread about your trans problem
Old 03-20-2011, 07:07 PM
302 Z28's Avatar
A tighter cable delays shift. Make sure that at idle the cable is slightly pulled out, it should never be slack.
Vince
No shifts from 1991 700r4 1936bowtie Transmission - Rearend 6 02-25-2011 06:54 PM
700R4 Shifts Too Soon 10mikeymike Transmission - Rearend 5 11-19-2009 07:20 AM
700R4 trans. shifts to hard beltman Transmission - Rearend 3 03-25-2009 10:11 PM
700r4 shifts pink63impala Transmission - Rearend 7 03-16-2005 04:57 PM
700R4 Shifts Keppie Transmission - Rearend 6 07-16-2002 11:48 PM
