1992-1994ish automatic 'chatter' - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2009, 04:43 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
My girlfriend's brother has a 1992-94 Cavalier 3sp auto, he's not sure what year it is, but it's the same bodystyle and I think they used the same trannys and stuff through those years (see pic for similar car).
looks just like this, only rustier and with four doors.
In any drive gear (including reverse) the transmission/torque converter 'chatters' and it shakes basically the whole car. It smooths out really well in neutral and park.
It's also 'chattery' when the car is first started in park. It smooths out after a few seconds.
Tranny fluid has never been changed, and at 145k miles on it, I think a tranny pan drop, new filter, and a little fluid would help reduce this chattering.
His dad (my gf's dad) says that automatics are made to be 'sealed' and it's fine and shakes since it's a cheap car. (fyi he's also a Honda guy...)
So, any input would be appreciated.
-Matt, and his gf's brother Kevin
Old 02-18-2009, 07:30 PM
boatbob2
SHAKE,,,,RATTLE and ROLL.........
HI,your girlfriends dad is missing a little common sense. transmissions with that many miles on them,need a filter change,new gasket,and some new oil...believe it (or dont) when you drop the trans pan,you are going to find a bunch of crud in it...guess where the crud comes from !!!inside the transmission.
Old 03-14-2009, 09:11 AM
Wiki Edits: 7
I kind of figured this, but thought I'd get some confirmation on the subject. Maybe there's someone else out there.
If anyone else has an opinion or sarcastic comment to post, feel free to do so after the beep. *beep*
Old 03-14-2009, 11:01 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
common sense or not.change the filter and the fluid and try some good additive from your local parts store. and it might help it and it might not but if he dont want to spend the money at a trans shop you have nothing to lose .and it might stop the chattering for now and add alittle more life to his trans. cole
Old 03-14-2009, 02:22 PM
Big Don's Avatar
Tranny
The problem is pump pressure as they get worn out. If the bands etc get too much free play then the pump has trouble keeping the pressure high enough to engage the banded gears all the way. Most of these series trans are similar and share the same problem when they get older, say 100k plus. Changing the filter and adding new fluid may help, but from my years of selling and fixing used chevy front drives I think it won't change much. The parts are worn and fluid can't fill up the spaces; its just seems like common sense would tell one that.
Question: Does it stay hung up in lock up when you come to a stop? The way to tell is that when you come to a stop the engine feels like it is stuttering and then dies. They all have this problem it seems. There is only one fix!
Old 03-14-2009, 07:32 PM
Wiki Edits: 7
Engine keeps running... just shudders when in a drive gear. Otherwise it runs smoothly. Would some thicker fluid help (such as that lucas trans fix stuff) as a 'band aid' to get a little more life out of it?
fastest muscle pre 1970 81elcamino Hotrodders' Lounge 86 01-19-2009 04:53 PM
fixing clutch chatter, everything is apart, what can I reuse? darkostoj Transmission - Rearend 7 11-04-2008 09:21 PM
Chatter In the Cylinder Head 1985chevy Engine 9 04-08-2007 12:12 PM
crown for king of the muscle cars Quarter mile killer Hotrodders' Lounge 48 08-20-2005 10:31 AM
Automatic vs Standard bowtieorbust Transmission - Rearend 11 03-25-2005 10:25 PM
