1992 Dodge Dakota stops shifting into third gear after transmission warms up
I have a 1992 Dodge Dakota LE 5.2 w/318. It stops shifting into 3rd gear (I'm assuming thats overdrive) after the tranny warms up. And until the tranny warms up when it does shift into 3rd gear its a little hard. It works great until it warms up. Could this be a transmission solenoid? Or could it just be needing a filter and fluid change? And if the solenoid is the problem is it hard to change? The speedometer works, its right on the money.
Thanks for your response
We put the used tranny in last year. Was told there was only about 80,000 miles or so on it. Unsure if its 3rd or just OD. When I take of from a still stop its the third time of shifting I am talking about around the speed of 47 to 50 MPH when it shifts. The second shift is at 45 MPH.
the 3rd shift your talking about, does the shift feel the same as the previous 2? or is it more of a surge, than a shift? and last, is there a 2 or 3 wire connector on the driver side of the trans just above the neutral switch? |
| Transmission Sometimes needs help shifting | Countilaw | Transmission - Rearend | 2 | 02-24-2007 12:08 AM |
| 94 Dodge Transmission Electronics problem? | Native Gearhead | Transmission - Rearend | 7 | 10-17-2006 10:00 PM |
| 97 Dodge Dakota | Rick527 | Transmission - Rearend | 3 | 05-29-2005 07:11 PM |
| 72 dodge dart transmission question | A/G WILLYS | Transmission - Rearend | 4 | 05-08-2005 01:04 PM |
| 38 Dodge Humpback Panel on Dakota Chassis> | sifua | Body - Exterior | 2 | 10-23-2004 02:37 PM |
