1992 GMC Sonoma will stock tranny hold up to V8? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2009, 12:34 PM
i am dropping a 400 small block chevy in a 1992 gmc sonoma, and i was wondering how well the factory tranny and real end would hold up. im not going crazy with the engine maybe in the 350 hp range. Any suggestions?
Old 10-29-2009, 06:21 PM
SSedan64's Avatar
If you have the 7.5"/7.625" 10-Bolt they're weak, Traction is what will kill it. The 8.5" 10-Bolt will be fine.
I'm not sure if your 700R4 has the 60degree bellhousing or 90deg bell. The 60deg wont bolt up to the V8. Either way the trans needs to be beefed up.
Old 10-31-2009, 05:06 PM
fast68's Avatar
likes chevy trucks & boobies
same rear as in most other cars as well and they dont come apart very often.
what kind of trans you got in it?
5 speed?
7004r?
run it til it breaks then worry about it
it may never break.,
all depends..
most ppl dont have an issue with the original trans when they put a v-8 in
Old 11-01-2009, 12:52 AM
92 gmc sonoma
i am running the 700 r4 but it has close to 300,000 miles on it.
Old 11-01-2009, 01:26 PM
scapegoat's Avatar
Swap it out, you will break it eventually. I put a th350 in my sbc'd s10 and never looked back.
Jasper 305 V8 and chevy stock trans. questions. Unfckngblvbl Engine 3 02-05-2005 07:39 AM
350 and 454/455 V8 stock HP and Torque? Malibu73 Engine 12 08-29-2004 05:36 PM
93 gmc cams that will work with stock setup tonyabillyd Engine 0 10-16-2003 11:38 PM
80 vette tranny.. what swaps with the stock 3 speed in the 350? jens42 Transmission - Rearend 2 08-26-2003 08:55 AM
Tranny Pans...Stock or Deep Dish?? TheZaZ Engine 1 04-24-2003 04:04 PM
