1992 I- Beam - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2007, 03:48 PM
need strog32 chevy front doors
Last journal entry: Tbd
1992 I- Beam
I found a frontend from a 1992 chevy. Didnt think they made these anymore. well was wandering if i could just put this front end in my 32 chevy. What would the complications be? To heavy any one have an idea of weight.
Old 09-08-2007, 06:45 PM
Thats Interesting doesnt really look likethe hevy duty I-beamslike you seeon service trucks I wonder if the truck had been a 4x4 and someone converted it over....do you have the vin?
Shane
Old 09-08-2007, 06:58 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Where is the pic?
Old 09-08-2007, 07:20 PM
its off of a 2500 chevy. I don't have the vin. The guy is selling the truck for 1000 with no tranny and engine. You guys don't think this is stock?
Old 09-08-2007, 07:26 PM
Lost in the 60's
Wiki Edits: 4
That front end will be too wide and too heavy to use on your 31, imho........also since that is a 3?4 ton PU axle it should have 8 lugs on the hubs....you definately would not want that on the front of a hot rod.
Old 09-08-2007, 07:51 PM
makes sense. How about with a 57 chevy truck front end???
Old 09-08-2007, 07:58 PM
Lost in the 60's
Wiki Edits: 4
Probably too wide. You can get a dropped axle for it from Speedway and you can either set it up with Ford or Chevy disc brakes. That is what I did on my 31. Check it out. www.speedwaymotors.com
Old 09-09-2007, 11:50 AM
dropped axle - how much do they lower the car. How com i don't see standard axles around.
H beam vs I beam orion Engine 19 09-12-2007 09:47 PM
Anybody running a Split I beam? Metal Twister Suspension - Brakes - Steering 6 06-25-2007 07:04 PM
Floor high beam switch gbowne1 Electrical 14 08-03-2006 11:10 AM
Sealed Beam headlights for 38 Chevy Coupe? beeb Body - Exterior 6 05-15-2005 08:06 PM
help replacing the high beam switch saenz5 Electrical 2 10-06-2004 07:36 PM
