-   -   1992 oldsmobile cutlass bogging out (http://www.hotrodders.com/forum/1992-oldsmobile-cutlass-bogging-out-202683.html)
metallica82010 07-26-2011 07:46 AM
ok i need help every time i hit 4000 rpms i stall or bog out i have changed the fuel filter cleaned the tank i have used sea foam what else could it be im lost please help me
cleanspeed1 07-26-2011 08:19 AM
Is your CEL ( check engine light ) on?
Have you tuned the engine up?
Have you done a compression check?
Valvesprings weak?
327NUT 07-26-2011 12:34 PM
Check your catalytic converter, they do get plugged up after a while.......same thing happened to our '93 Buick years ago. Oh and make sure you do that before tearing your heads apart to check the valve springs.
FmrStrtracer 07-26-2011 02:35 PM
I would check the converter before anything else also
