1992 oldsmobile cutlass bogging out - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2011, 07:46 AM
ok i need help every time i hit 4000 rpms i stall or bog out i have changed the fuel filter cleaned the tank i have used sea foam what else could it be im lost please help me
Old 07-26-2011, 08:19 AM
Is your CEL ( check engine light ) on?
Have you tuned the engine up?
Have you done a compression check?
Valvesprings weak?
Old 07-26-2011, 12:34 PM
327NUT's Avatar
Check your catalytic converter, they do get plugged up after a while.......same thing happened to our '93 Buick years ago. Oh and make sure you do that before tearing your heads apart to check the valve springs.
Old 07-26-2011, 02:35 PM
I would check the converter before anything else also
1992 cutlass supreme convertible metallica82010 Hotrodding Basics 1 06-30-2011 02:52 PM
oldsmobile 330 heads on an oldsmobile 305 JohnnyBoy Engine 8 08-11-2009 10:37 AM
89 oldsmobile cutlass ciera Medz Introduce Yourself 3 08-13-2008 08:21 PM
q-jet bogging down 305 chevy Engine 5 06-09-2007 06:20 PM
350 sbc bogging Gearhead70Chevy Engine 9 04-26-2003 03:16 PM
