1993 c3500 dually with 4l60e trouble - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2006, 07:09 PM
1993 c3500 dually with 4l80e trouble
i just bought this truck, and it shifts good through 1 2 and drive. but it will not go into overdrive. a couple of times i noticed that it would take off in 2nd gear and not shift at all. i took the ground cable off the battery, and let it sit for 10 minutes, hook it back up, and back to shifting it goes, but still no overdrive. all the wiring and the trans are factory, never replaced. the ecm looks to be brand new though. could this be a programming issue, or perhaps the wrong ecm? also, should the ecm be grounded, as it is just sitting in the dash not even in a bracket currently. thanks, bgboy
Old 07-02-2006, 07:12 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
This is a Hot rod site....What does a ton dually have to do with hotrods?
Old 07-02-2006, 07:16 PM
transmission answers
i just thought that maybe someone out here may have some info that may help me. besides, my dually is my daily hotrod, and my weekend hotrod hauler! thanks, bgboy
Old 07-02-2006, 07:37 PM
airworld2's Avatar
93 1 ton
should be 4l80 e not 60e
you should have this truck scanned for trouble codes before you proceed any farther.
Old 07-02-2006, 07:41 PM
sorry, it is indeed the 4l80e
i posted the wrong trans #. i have corrected it now. it does have the 4l80e. sorry, and thanks for the reply, bgboy
Old 07-04-2006, 06:53 PM
anyone?
does anyone else have a clue where to look? thanks, bgboy
Old 07-04-2006, 09:03 PM
Crosley's Avatar
Wiki Edits: 1659
you received a high quality answer from airworld2:
there is a series of tests to run with a high quality scanner to help determine the area the problem is in.
Test solenoids, checks codes ( old and new) watch the data stream from the PCM to the tranny to see if the proper commands are there.
Sometimes there is no magic simple answer, you must diagnose the problem with the proper tools.
1979 Dually trouble help PLEASE! 79dually General Rodding Tech 1 05-23-2006 06:05 PM
Diagnostic Trouble Codes - 1993 Taurus GL awbazar Electrical 4 09-18-2005 08:09 AM
4L60E Trouble StrtCrazed4Life Transmission - Rearend 2 04-20-2004 08:28 AM
4L60E trouble with overdrive Please Help Transmission - Rearend 2 03-19-2004 07:20 AM
1990 Chevy C3500 Dually transmission tony4931 Transmission - Rearend 1 02-17-2004 01:06 AM
