1993 Caprice Wagon rear brakes/tires/rims - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2007, 03:32 PM
I need new rear wheel cylinders, and my drums are either 11" or 9", and I don't know what to measure to call out the correct cylinder. Which do I measure - ID or OD??
Also, I mounted P235-70-R15 BF Goodrich Radial T/As on stock rims on the front, and it seems to fill the wheel wells nicely. I think I want wider ones in the back, since on the Wagon it's 3" wider. I'll be putting old-school Cragar-type rims all around, but I'm not sure how wide. What's the best way to determine desired rim width/tire size?
Old 09-12-2007, 11:09 PM
Your drums would be the 11 inch ... on a wagon
A homemade tool like the one Powerodsmike made works well ...
Old 09-16-2007, 01:22 AM
Chopt 48's Avatar
Make sure that the weight of the car is sitting on the axle when you do that to have it in the correct position.
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 09:03 AM
65 Chevelle Wagon 2002 Camaro rear end Mic Mercer Transmission - Rearend 2 06-23-2006 05:35 AM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 10:50 PM
Rear end Buffed Engine 3 10-31-2002 05:11 AM
Rear quarter glass for 56 Chevy Wagon bigjoedo Body - Exterior 5 07-01-2002 02:42 PM
