1993 Chev. Suburban 2wd 4L60E Problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2009, 08:42 PM
This is my first post here. I have visited alot and learned alot from it. So thanks to everyone in advance for info that I have taken and info that I will receive in the future.
My problem, I have a 1993 Chev. Suburban 2wd. I had trans rebuilt. Worked fine for 2 years. Motor went down so I rebuilt motor. Sub sat for 6 months. When I put the motor back in trans would not work right. Here is what it does, when cold it will shift through the gears great. After 5-10 min. it goes straight to 4th. Will not shift down. So I shift it manually. 1st, 2nd, 3rd, and so on. It will shift great that way. We thought it might be something electrical in the trans, so we changed everything. Still the same. Changed computers in sub. Still the same. We thought it might be losing pressure when it got hot, so I was going to take it out and rebuild it again. But before I could do that last week, the trans quit. Would not pull or anything. So I took it out and had it rebuilt. Found that the torque converter was out, and alot of metal inside. Put it back in last night. Same thing still happens. Did not change one thing. Somebody please help on this. There has got to be something I am over looking.
Old 10-25-2009, 09:54 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
truck72 .. welcome to Hotrodders.com
We do not use PLEASE HELP in thread titles here. There are some real sharp folks here that will help you without begging.
I would suggest the use of a device commonly known as a Shaffer Shifter to control this transmission on a test drive while the trans is warmed up where the shift problems show up.
this Shifter device is generally in a larger shop. Some shops may have a different brand of controller to remove the trans from the vehicle control systems.
If the isolated transmission still shifts to 4th gear when it should be in first gear electronically while OFF the vehicle computer system , the problem is inside the trans.
If the trans operates correctly on the stand alone controller .. the problem is in the vehicle system
Old 11-05-2009, 06:33 AM
chevy sub 4l60e problem
Took it to a shop this week. Computer is trying to go into 4wd low. When it does this is when the trans is acting up. It is a 2wd. Any suggestions?
4l60e problem 93 suburban hecfrombx Transmission - Rearend 21 04-04-2009 07:40 AM
1993 Suburban Transmission Swap dlac1769 Electrical 1 10-30-2004 02:09 PM
1993 Suburban k1500 Transmission upgrade dlac1769 Transmission - Rearend 3 10-23-2004 07:26 AM
4L60E transmission problems BICHN69 Engine 1 08-14-2004 11:23 PM
4L60E shift problems 68vortec Electrical 0 07-10-2003 11:10 AM
