Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1993 Chevy 5.7L TBI heater hose port location
Old 03-02-2012, 06:03 PM
BogiesAnnex1 BogiesAnnex1 is offline
Originally Posted by Infinite Monkeys
Thanks again Bogie.
For what it's worth, I put the 1995 pump with the heater hose port on it and it fit just fine. Right now I have the manifold and the water pump ports hooked together till I get around to putting in a heater.
Thanks
As long as you're aware that a 1995 is a reverse (counter clockwise) rotation pump and only works with a factory serpentine belt system or an aftermarket that runs the belt under the pump pulley like the OEM does. If you're using older V-belts or an aftermaket serpentine that goes over the pump pulley, then you need the older clockwise rotation pump. Same goes for fan if it's being turned by the pump.
It just never stops coming at you with these things anymore.
I'm getting out of here for the night, we're running a dyno simulation and the damn program keeps locking up, I just don't want to mess with it any more.
Bogie
