1993 Chevy Silverado cruise control - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2005, 11:07 AM
Kevin45's Avatar
Just one of the guys
It doesn't work. Any ideas as to where to start looking or what it might be. All I know is that it is not a fuse.
Kevin
Old 08-21-2005, 06:44 PM
docvette's Avatar
Wiki Edits: 12
Cruise control
Doc here,
Electronic? or Vacuum..or both.? Both I think..on that car..Anyways..
Won't come on..check for Vacuum to canister to actuator..via switch and BBox..(in on) If that is good (holding Vacuum) the speedo cable may have broken, thinking it's at idle at any speed..those are 2 piece too so check both sides.
Won't turn off, open brake light wire to the switch from the Bbox..
That should get you started anyway..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 08-21-2005, 07:05 PM
Kevin45's Avatar
All electronic. No vacuum. One fuse and it is good as it runs both the gauges and cruise so I know that is not it.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
700R4, cruise & electronic speedo 302 Z28 Transmission - Rearend 10 10-31-2003 12:28 PM
'88-'98 Chevy Silverado dannimo Interior 1 08-13-2003 08:53 AM
Cruise Control. DoubleVision Electrical 3 04-05-2003 09:13 AM
1999 Chevy Silverado Transfer Case/Transmission? officialfoxracer21 Transmission - Rearend 2 12-15-2002 04:56 PM
