1993 dakota 5.2L transmission 2wd problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2012, 09:53 AM
I rebuilt my dad 93 dakota 5.2l transmission 2wd what i belive to be a 46/47 re/rh. I cleaned everything and did the rebuild everything went right nothing broke the old bands where burnt to nothing just metal rings left.
Now after we re-installed the transmission new fluid ATF +4 the transmission works great but no OD.
Here is where i need help when the trans get hot (to temp) it wont pull at all. I have asked 3 trans shops valve body needs cleaned did that needs a new governor pressure solenoid did that nothing.
What am i missing we need a trans guy to help use out on this 1 all i know is dodge transmissions SUCK.
1993 Ford Taurus Transmission problems Wanda79 Transmission - Rearend 1 05-08-2011 11:41 PM
Dodge Dakota 2wd 5 speed manual trans Deadmetal Transmission - Rearend 2 11-29-2010 06:53 AM
1998 V6 Dakota Transmission problems KenCam Transmission - Rearend 3 07-15-2010 10:26 PM
1993 Chev. Suburban 2wd 4L60E Problems truck72 Transmission - Rearend 2 11-05-2009 06:33 AM
Dodge Panel Delivery with a 1993 Dakota Chassis 2craze Introduce Yourself 1 10-08-2007 06:43 AM
