1993 GMC sonoma 2.8L swap or rebuild ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2003, 10:40 AM
I need some help! I have a 1993 GMC Sonoma pick up with a 2.8 liter V6, 5 speed tranny. It will be replaced soon but I need more power! I pull a boat with it and there are a lot of hills and mountains around here! I don't fish enough to warrant a new payment book so what do I put in the truck? A swap that is parts compatible to the 2.8L? Do I put Hi-Perf. parts in the 2.8L? Someone tell me the smart solution to getting more power without having to change everything from the tranny to the rear end. Can I use headers w/o any trouble? I am going to go the economical route but will have installed what works best. The body will be painted afterwards so this will be a complete restore on the truck. Thank you very much !
Old 08-24-2003, 12:26 PM
datsun350's Avatar
If I were you I would do anything that I could to get that 2.8 out from under the hood of your truck. A small block is a common replacement and fairly easy to do and a 4.3 came stock in those trucks and should have gobs more power than any 2.8 I have ever seen. I didn't know they still offered a 2.8 in 1993 i thought they discontinued that................
Old 08-24-2003, 02:12 PM
V8 S-10's Avatar
v8s10.org
Heres several links for you
60 degree v6 Performance parts
http://www.s-series.org/htm/performance/60degree.php
Weber carb conversion
http://www.weber-carburetors.com/Web...20P/U%20Blazer
Putting a Camaro/Firebird 3.4 in place of a 2.8 is a common mod (probably what i would do in your case)
http://forums.s-series.org/viewtopic.php?t=52
Or if you decide to go V8 you should find a TBI 350 or 305 to put in.
Old 08-24-2003, 02:38 PM
yep... go with a 305 or 350, 305 will be lots for your use, if you want something that'll spank 5l mustangs then get the 350
87 ex cab s-10, 355, b&m th350, soon to be trubocharged
http://www.v8s10.org/gallery/view_album.php?set_albumName=album02
Old 05-27-2005, 09:12 AM
I would go with a small block but if you really want to keep the 2.8 they do make a supercharger for it you could look it up or you could put in a 4.3 your choice. I would go with a carbed 305.
Old 03-05-2006, 12:47 PM
eddbadger's Avatar
A friend of mine and I have replaced the 2.8 with the Camaro 3.4 and have been really impressed with the added power and reliability. Of course this is an easy direct replacement. We used the TBI from our 2.8s along with the intake manifold. There is a mod to put the MFI in the system in also, but with our vehicles we were looking for cheap and reliable. The bell-housing on my 5 speed was removable so the 4.3 probably would have been nearly as easy to put in, and obviously more cubes is more power. Another friend has put a 350 in his S-10 and been tickled with it, but there were some mods he had to make to get it in, like new motor mounts. As for the rebuild, I personally wouldn't because of the anemic power and the cost of the rebuild could get you a lot stronger engine going the swap route. Good luck.
Old 04-23-2006, 10:32 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
GM offers a 3.4L HT (high torque) v6 (history... 2.8L to 3.1L to 3.4L to 3.5 and 3.9L) in its speed parts catalog
Old 04-23-2006, 11:51 PM
onebadmerc's Avatar
I need a bucket of arc sparks
Dump the 2.8 and put a 4.3 in that 93 Sonoma. Even though I am a Ford and Chrysler guy, I have total respect for those 4.3 GM engines.
