Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1993 mivan w 3.3 L engine tranny problem Help
Old 08-25-2003, 02:09 AM
CET's Avatar
CET CET is offline
il enforcer
After being raped repeatedly ( in the wallet ) by the wifes '92 model Caravan my first question is: did you use dextron fluid? If so drain it and fill with ATF 3.
Have you flushed the tranny?
We bought our 92 and shortly there after the thing shifted abruptly and you had to warm it up or the vehicle would not move. Draining the Dextron the previous owner used ( found MR Lube receipt ) and filling with ATF 3 solved the problem.
