Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1993 mivan w 3.3 L engine tranny problem Help
Old 08-25-2003, 06:10 AM
airworld2's Avatar
airworld2 airworld2 is offline
tranny trouble
limp in is second gear and trans will not up shift, usally turning the key off then re-start engine will reset trans computer... if trans doesn't have hard fault code ie speed sensors, solenoid pack
you should take it to a tranny shop to let them scan it for codes. 36 fault after shift will be first 52 53 54 all most common codes 24 and 39 are or should I state usually solenoid pack codes. do you know any history of the car as to trans repair, cry update inside rubber seals as of 95 and up 604 and 606 trans.
