Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1993 TA with 700R4, leaks oil after shut off
Old 10-07-2012, 07:44 AM
FIFS93TA FIFS93TA is offline
And it may be just the distance to make it flow over at the dipstick tube? It drops out about half a litre if I top it up and if I don't top it up it's wont discharge any at all. Could it be that when I refill it it's just not leaking because the fluid is still to thick at this point to leak? As you can tell I'm no professional mechanic but I do most of my own work. I dropped the pan and replaced the kickdown cable grommet, filter and gasket ( torqued to 12ftlbs) now I'll take a look at the dipstick tube and get back to you. Thanks so much for the help guys!!
