Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1993 TA with 700R4, leaks oil after shut off
Old 10-09-2012, 06:01 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by FIFS93TA View Post
So it's definately coming from the kickdown cable!! I changed the grommet ("top hat style") and its still leaking. I have two questions. Is the top hat style the right one for the 700R4? Should I have done anything else before replacing it (red gasket maker? Anything?) thanks guys
How was the cable and sealing sleeve installed?
Did you slide the sleeve (grommet) onto the cable first, then slide that whole assembly into the case? Incorrect method.
Did you install the sealing sleeve (gromet) into the case first , then install the lubricated cable end into the sleeve? Correct method
