Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1993 TA with 700R4, leaks oil after shut off
  #19 (permalink)
Old 10-11-2012, 09:38 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by FIFS93TA View Post
Any chance I could put a rubber washer around the hole aswell and tighten it up? Or will that not work? I'm at a loss here.... Everything was done correctly and there are no faulty parts because I just checked them all because I had suspicion of a melted cable but it's fine.... I don't know what to do next.
I've been in the trans biz for 3 decades.
Since you have all good parts installed correctly on the TV cable, the leak is not there. I suggest you look near by the TV cable
