1993 TA with 700R4, leaks oil after shut off - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-10-2012, 12:40 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by FIFS93TA View Post
I used the second method but I didn't lube the cable. Will that alter the outcome?
If you tore the rubber sleeve , trans will leak oil. If the plastic on the TV cable is cracked, it will leak
  #17 (permalink)
Old 10-10-2012, 03:50 PM
I can't figure out how to upload pics onto here but I think the cable looks melted at the tip. ?!?!
  #18 (permalink)
Old 10-11-2012, 08:08 AM
Any chance I could put a rubber washer around the hole aswell and tighten it up? Or will that not work? I'm at a loss here.... Everything was done correctly and there are no faulty parts because I just checked them all because I had suspicion of a melted cable but it's fine.... I don't know what to do next.
  #19 (permalink)
Old 10-11-2012, 09:38 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I've been in the trans biz for 3 decades.
Since you have all good parts installed correctly on the TV cable, the leak is not there. I suggest you look near by the TV cable
  #20 (permalink)
Old 10-11-2012, 09:49 PM
Last journal entry: was hoping for better than this
whats the gear selector look like, dry or wet..
700r4, trans am, transmission leak, transmission repair
oil leaks from hp oil pump??...help please!! mikebutt Engine 9 06-05-2012 05:32 PM
700R4 oil Leaks meenaismymonte Transmission - Rearend 1 12-11-2010 03:18 PM
oil leaks DeaconJ Engine 2 05-27-2010 01:22 PM
1993 700R4 confusion ET1wilson Transmission - Rearend 5 11-30-2009 08:26 PM
oil leaks carnell Engine 10 12-14-2003 07:31 PM
