1993 TA with 700R4, leaks oil after shut off - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2012, 07:52 PM
Hey Guys!
I have a 93 TA with a 700R4. It only leaks directly after shut off. It leaks out about half a litre when it's warm as soon as I shut it off. It would appear to be coming from the general direction of the kickdown cable area. It's wet all over that passenger side. I just changed the grommet, gasket and filter while I was in there and it's still leaking out. Any ideas on what else is around there that would cause this. It's hard to pin point cause it only does is after driving then shutting it off and I don't have a hoist. Any help would be greatly appreciated.
Old 10-06-2012, 08:47 PM
TexasT's Avatar
Did you ever wonder?
Last journal entry: New stuff came in the mail.
The tv cable gasket might be leaking. or the grommet at the dipstick tube.
Old 10-07-2012, 06:19 AM
Would that only leak when when it's shut off after being driven until its hot?
Old 10-07-2012, 06:52 AM
Crosley's Avatar
Wiki Edits: 1659
Welcome to Hotrodders . com
I edited the thread title. Please place information on the subject in the thread title so the membership has an idea by this title what your problem is.
Trans oil expands and thins out when hot. The level of the oil in the trans is higher slightly. This can cause a leak, when there is no leak while cold.
Old 10-07-2012, 07:44 AM
And it may be just the distance to make it flow over at the dipstick tube? It drops out about half a litre if I top it up and if I don't top it up it's wont discharge any at all. Could it be that when I refill it it's just not leaking because the fluid is still to thick at this point to leak? As you can tell I'm no professional mechanic but I do most of my own work. I dropped the pan and replaced the kickdown cable grommet, filter and gasket ( torqued to 12ftlbs) now I'll take a look at the dipstick tube and get back to you. Thanks so much for the help guys!!
Old 10-07-2012, 08:07 AM
SSedan64's Avatar
When the engine's running the fluid level is about even with the Pan mounting surface. After shut off the TC/TorqueConverter drains back into the pan which raises the fluid level. It can then leak out the front/rear, TV cable, Dipstick, Shift shaft or Speedo seals if they're old/dry/worn.
Old 10-07-2012, 12:58 PM
Will I need to drop the transmission to do this or am I blind and just don't see it from under the car?
Old 10-07-2012, 01:41 PM
joshp83's Avatar
owner of Prices Garage
to get the dip stick out of a fbody it a tight sqeeze if u plull the trans be best to replace all the seals while you have it out
Old 10-07-2012, 01:47 PM
Is it a must? I did the kickdown cable yesterday and it was a really tight squeeze too. How is it in comparison? I'll have to get under it tomorrow and take a look. Thanks so much.
Old 10-07-2012, 04:57 PM
joshp83's Avatar
yea u have to unbolt the filller tube so u have to drop the cross member and torque arm
Old 10-09-2012, 08:34 AM
So it's definately coming from the kickdown cable!! I changed the grommet ("top hat style") and its still leaking. I have two questions. Is the top hat style the right one for the 700R4? Should I have done anything else before replacing it (red gasket maker? Anything?) thanks guys
Old 10-09-2012, 06:01 PM
Crosley's Avatar
Wiki Edits: 1659
How was the cable and sealing sleeve installed?
Did you slide the sleeve (grommet) onto the cable first, then slide that whole assembly into the case? Incorrect method.
Did you install the sealing sleeve (gromet) into the case first , then install the lubricated cable end into the sleeve? Correct method
Old 10-09-2012, 06:07 PM
I used the second method but I didn't lube the cable. Will that alter the outcome?
Old 10-09-2012, 06:13 PM
Also how tight should it be? I can't get a tourque wrench up in there but I can make it close.
Old 10-10-2012, 08:36 AM
SSedan64's Avatar
About 6 -10 ft/lbs. Not much.
700r4, trans am, transmission leak, transmission repair
oil leaks from hp oil pump??...help please!! mikebutt Engine 9 06-05-2012 05:32 PM
700R4 oil Leaks meenaismymonte Transmission - Rearend 1 12-11-2010 03:18 PM
oil leaks DeaconJ Engine 2 05-27-2010 01:22 PM
1993 700R4 confusion ET1wilson Transmission - Rearend 5 11-30-2009 08:26 PM
oil leaks carnell Engine 10 12-14-2003 07:31 PM
