1993 Taurus Axod-E Transaxel - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-24-2006, 07:24 PM
I am getting codes 628 (lock-up solenoid circuit failure) and 634 (manual lever position sensor out of self test range) on a 1993 Taurus GL.
I did the procedure to correctly set the manual lever position and eliminated the codes for several days. The transmission now occasionally does peculiar shifts from 3 to 4 and occasionally the drive in 4th appears to cut out momentarily when driving around 65 mph on long hauls after 2 or so hours of driving. Both codes have come back again and I repeated the manual lever adjustment without any luck eliminating the codes this time.
Does this sound like a trip to the transmission shop or do I need a more careful adjustment of the manual lever? Any tips would be helpful.
93 Taurus GL Temperature Range awbazar Hotrodding Basics 7 06-28-2011 07:29 PM
3.0 taurus with intermittent spark fumplet Engine 0 03-04-2006 08:10 PM
Diagnostic Trouble Codes - 1993 Taurus GL awbazar Electrical 4 09-18-2005 08:09 AM
3.8 litre 1993 taurus other problems steve norman Engine 0 12-02-2002 08:37 PM
3.8 litre 1993 taurus won't keep running when in gear steve norman Engine 6 12-01-2002 07:37 PM
