1994 Camaro 10 Bolt Rear Dics Brakes? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2010, 07:21 PM
Tribal's Avatar
THUG LIFE
I've got a Ford 9" that I'm narrowing for a 70 Camaro & the guy wants to use his stock 1994 Camaro rear disc brakes. I plan on ordering a set of Moser Engineering housing ends # 7900FM. What I don't know is how far the axle flange has to stick out past the housing flange, and what do I use for bearing retainers? If anybody has the info I need it would be appreciated.
Old 01-29-2010, 07:38 PM
ericnova72's Avatar
More for Less Racer
Go to Moser's site and click on the install instructions for the 7900FM housing ends. It appears that the caliper bracket is also doing double duty as the bearing retainer.
Old 01-30-2010, 07:42 PM
Tribal's Avatar
THUG LIFE
Thanks, I've never noticed there install instructions before. It answers most of the questions I have. I still don't know the axle stand out, distance from the axle flange where the rotor slides up against to the housing flange where the caliper bracket bolts to. If I had the original axle housing & axle shafts I'd know what the stand out would be.
trunk lid problems gto_ron Body - Exterior 35 12-20-2009 08:09 PM
TH350 and 10 bolt rear end... rezervation_pitbull Transmission - Rearend 3 10-03-2007 02:59 PM
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 07:10 PM
68 Camaro 10 bolt & 2000 truck limited slip 68CaliCamaro Transmission - Rearend 6 12-22-2003 04:57 PM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
