Start a tech article on any subject...
...hundreds of hotrodders help build it into a comprehensive resource.
Fresh wiki articles that you can add to: Air suspension on a front solid axle, Basic stuff for newbies, Building a new shop, Ceramic insulation, Electric fuel pump mount, Engine and transmission mounts, Freeing a stuck engine, Gasser, How to check driveline angle, How to make a vacuum power brake bleeder, How to safely cut steel with a torch, Improving fuel economy, Narrowing a rearend, Patching a body panel, Quick-disconnect rear mount battery, Reducing vehicle weight, Stereo installation, Stripping paint, Valve spring setup, and many more...
Or, start a new article.
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 05-09-2008, 10:28 AM
mitchc mitchc is offline
1994 Chevy C1500 Vibration
Hey Guys and Gals..
This is not a Hot Rod question but one that is driving me nuts.. I have a 1994 Chevy C1500 ext cab pickup that I changed the Carrier Bearing a couple weeks ago and I now have this vibration that is driving me nuts. I had the tires balanced again and its still there. I checked the phasing of the drive shaft and it can only go back to gether one way, the front shaft is splined and keyed. The ujoints were in pretty good shape and had grease zerts and I greased everything when I put it back together..
Any thoughts??
thanks
Mitch
Old 05-09-2008, 11:36 AM
123pugsy's Avatar
123pugsy 123pugsy is online now
re: 1994 Chevy C1500 Vibration
Check to see if the hanger bearing is 90* to the driveshaft.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "1994 Chevy C1500 Vibration"
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 221 11-06-2008 02:20 AM
56 chevy vibration at 55mph and up oldchevy1956 General Rodding Tech 5 07-22-2007 07:20 AM
91 model SS chevy C1500 Alternator Chris@whiterhino Electrical 2 06-01-2007 11:12 PM
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 59 04-08-2007 11:25 PM
4:10's for Chevy C1500 RedLightedAgain Transmission - Rearend 0 07-10-2002 10:31 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
