1994 chevy truck 4.3 to 5.7 swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2007, 08:08 AM
will motor mounts work without mods
Old 12-16-2007, 09:37 AM
poncho62's Avatar
Wiki Edits: 5
I think they just have to be moved forward.........could be wrong.
Moving this to the engine forum, they should know.
Old 12-16-2007, 01:07 PM
DoubleVision's Avatar
On my 92 chevy pickup with a 4.3, It has adaptors that bolt up where the small block holes are in the frame. They are swept back and I`m guessing this was the cheap and effective way for the factory to save money as well as provide the 8 inches of difference in the mounting points between the V6 and V8. If the adaptors are removed you should be able to bolt up regular small block mounts and drop in your V8, unless at some point they stopped using these and bolted the mounts directly to the frame. Even if they did the small block holes will still be present in the frame.
Engine swap Chevy 350 ina a Datsun 521 truck evh5150 Hotrodding Basics 17 09-12-2007 10:58 AM
looking for a pic - the Navarro (?) families 68/69 chevy truck lowROLLERchevy Hotrodders' Lounge 0 10-03-2006 03:24 AM
nova subframe on a 59 chevy truck bet on black Suspension - Brakes - Steering 3 01-27-2005 08:48 PM
1967 Chevy Truck Gear Ratio 53chev Transmission - Rearend 3 01-27-2005 07:49 PM
54 Chevy truck frame swap J.Ogle Suspension - Brakes - Steering 4 11-25-2003 06:56 PM
