Thread Tools Search this Thread share on Facebook
  #1
Old 12-22-2011, 10:31 AM
7hr Reaperxx 7hr Reaperxx is offline
1994 corvette hesitation
I have a hesitation and have had this problem several times with varying symptoms. this time I am kinda stumped. The car doesn't turn on its check engine light and runs like it has a bad tank of gas. Idles a lil rough but when you give it trottle it seems to be... a few cylinders short, runs ok at full throttle but pings. (and heads for ditch) lol Have recently changed the oxygen sensors as they were bad (checked with a scan tool). no codes no info from scan tool. what could cause this to happen and not throw a code. mass air is not new but has less than 50k in it same with water pump and optispark, there are no leaks I can see near the opti-spark so I think Its ok. The car itself has 187k on it ussually runs great no knocks and good compression on all cylinders.
Register now (free) or login to remove ads
Old 12-22-2011, 10:45 AM
31Vicky's Avatar
31Vicky 31Vicky is offline
What about the fuel injectors?
Old 12-25-2011, 11:03 AM
those are still the factory parts. I regularly use fuel tank injector cleaners
I use the bottles of injector cleaner bout every 4th tank but they have never been out of the car to be cleaned. Discovered yesterday that the car runs perfect till it warms up. then starts the same hesitation and it is apparently going to do that until it has sat overnight. only runs good till it comes up to operating temp. There is a little temp sensor on the water pump, I am going to replace it 1st since its easy to get to. It might need a fuel filter as well its been about 60k since it was replaced. Injectors are for sure a concern though with the milage on this car. Thanks for the help.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "1994 corvette hesitation"
ThreadThread StarterForumRepliesLast Post
1994 Corvette restorationRghentIntroduce Yourself312-14-2011 06:38 PM
hesitation1966 CHEVELLEEngine204-07-2010 05:01 PM
1994 corvette covertible top replacmentdonkeydawn11Interior203-02-2010 12:27 PM
Corvette Summer Corvette Front ClipMADTECH72Body - Exterior1804-16-2008 07:45 PM
Hesitation1969NovaSSEngine508-01-2005 09:11 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
