1994 Dodge 2500 Cummins clutch problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2011, 02:53 PM
chevy1500z71's Avatar
So i have known that my old cummins has needed a clutch since the day i bought it, it slips pretty good in 5th but i really dont mind it, its just my beater/daily driver type truck. but the other day on my way home i noticed that after i started the truck i couldn't get it into gear, the clutch was not engaging but the pedal felt fine. so i put it in low and started it in gear and once the truck started it broke it free and clutch worked again, after that the clutch sort of worked intermittently, sometimes id have to press the pedal 5 or 6 times before it actually worked and let me switch gears. so this morning i looked and the fluid was a little low, i topped it off and drove the truck around and beat on the clutch a bit and it seems ok now but im woried that this is gonna happen again. one time i let the clutch out i swear i could hear a grinding noise. so what do you guys think? i was leaning towards a hung up slave cylinder, clogged line, air in the system, low fluid, or something like that but im kinda unsure now that i heard it make some grinding noises.
ideally id like to just pull the trans and take a look but i was supposed to take the truck out mudding tomorrow and if i dont have the truck going nobody's going muding, im the only one with a 4x4 amongst my friends lol.
the truck is a 94 dodge 2500 cummins, the trans is an nv4500 5 speed. and its an internal slave setup.
Old 07-30-2011, 06:42 AM
tnsmith10's Avatar
when will it rain???
on a manual trans, if the clutch wont disengage, its because the input shaft is still turning when you push the pedal down. more than likely, the pilot bearing is going to be the culprit. and odds are that its going to have a roller bearing type pilot. it is not uncommon for the needles to dry out and eventually wipe out the pilot bearing.
that could explain the grinding noise you heard.
Old 07-30-2011, 08:36 AM
willowbilly3's Avatar
Last journal entry: Body mods
You really should pull it apart now rather than take a chance on ruining something like an input shaft.
97 dodge ram 2500 wayneooo Engine 11 03-02-2012 09:20 AM
1994 Chevy 2500 6.5 diesel kphillips1953 Engine 3 06-09-2011 10:38 PM
2005 Dodge 2500 5.7 Hemi jumm Electrical 2 05-19-2011 02:20 PM
Dodge Ram 2500 concerns before purchase kadi Hotrodders' Lounge 9 09-26-2008 03:47 PM
Need info on 1998 Dodge 2500 p/u oldscout Transmission - Rearend 1 06-05-2003 06:26 PM
