-   Modern Electronic Engines (http://www.hotrodders.com/forum/modern-electronic-engines/)
-   -   1994 dodge intrepid fuel probs (http://www.hotrodders.com/forum/1994-dodge-intrepid-fuel-probs-214396.html)
jerryvarnell 02-10-2012 12:54 PM
My fiances car is acting up
It's flooding runs rough and the inside smells like gas when she drives it
No codes are thrown so I don't think its a sensor. What could it be?
EagleMark 02-10-2012 03:11 PM
That could definatly be and probably is, one of the most common problems every assciated with EFI cars! ANYTHING? :D
First a new car flooding should not smell like gas if it has a catilitic converter it should smell like rotten eggs.
If you smell gasoline I would look for a fuel leak. No reason to ever smell fuel on a newer car unless your pumping gas. Charcaol canister lines? Pretty sure those cars have a return line and if she has recently hit something under car could have collaspsed retuen line and got a leak and cause obstruction which would raise fuel pressure and cause flooding.
Check fuel leak.
Check fuel pressure.
LATECH 02-10-2012 06:12 PM
I would look around for a fuel leak on top of the motor,if nothing there, locate the evaporative canister and see if it is filling with gas. The vapor check valve in the tank can fail and allow raw fuel into the evap.
My money is on a fuel leak, probably injector seals.
jerryvarnell 02-19-2012 10:28 PM
Well I fixed it. Cleaned the maf sensor with brake cleaner.
Who woulda thunk it? ;)
