1994 dodge intrepid fuel probs - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 02-10-2012, 11:54 AM
My fiances car is acting up
It's flooding runs rough and the inside smells like gas when she drives it
No codes are thrown so I don't think its a sensor. What could it be?
Old 02-10-2012, 02:11 PM
EagleMark's Avatar
GearHead-EFI.com
That could definatly be and probably is, one of the most common problems every assciated with EFI cars! ANYTHING?
First a new car flooding should not smell like gas if it has a catilitic converter it should smell like rotten eggs.
If you smell gasoline I would look for a fuel leak. No reason to ever smell fuel on a newer car unless your pumping gas. Charcaol canister lines? Pretty sure those cars have a return line and if she has recently hit something under car could have collaspsed retuen line and got a leak and cause obstruction which would raise fuel pressure and cause flooding.
Check fuel leak.
Check fuel pressure.
Old 02-10-2012, 05:12 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
I would look around for a fuel leak on top of the motor,if nothing there, locate the evaporative canister and see if it is filling with gas. The vapor check valve in the tank can fail and allow raw fuel into the evap.
My money is on a fuel leak, probably injector seals.
Old 02-19-2012, 09:28 PM
Well I fixed it. Cleaned the maf sensor with brake cleaner.
Who woulda thunk it?
Recent Modern Electronic Engines posts with photos
1994' Dodge Dakota trans match up trblmker Transmission - Rearend 22 11-15-2009 07:57 AM
1994 Dodge Dakota late shifting from 1st to 2nd trblmker Transmission - Rearend 1 08-08-2009 12:30 PM
2002 Dodge Intrepid - O2 sensor troubles Hammer350 Engine 2 02-13-2009 02:47 PM
2002 Dodge Intrepid - Which side is Bank 1? Hammer350 Engine 2 01-29-2009 09:37 AM
5.2 1994 dodge quit runnin. poy41 Engine 1 05-14-2007 09:44 PM
