Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1994 Saturn Transmision Problem
Old 01-18-2006, 06:59 PM
xk8 xk8 is offline
Saturn transaxle problem
I just bought a 93 Saturn SC2 for a $100 bucks. It has a transaxle problem when you put it in reverse or drive it won't move but first second and third are ok, but if you just pull back the shifter about 1/16 inch when its in drive or reverse it will drop into gear and go. I checked the adjustment for the park neutral switch and shifter cable all ok. My research on the web tell me that valve body gets iron deposits in it and thats what causes the problem. I ordered a transaxle TAAT manual to disassemble the valve body to clean and repair it.
