1994 z71 4l60e Transmission problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2012, 07:05 PM
Hey I got a 94 z71 4l60e has only reverse any ideas on what is wrong
Old 01-07-2012, 07:10 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
welcome to Hotrodders.com
I edited the thread title to provide members with more information.
If you have no forward movement, there is an internal problem with the forward clutch, forward sprag or the low - reverse roller clutch located in the center support.
Have you tested full shifter range all the way to manual 1 to see if the vehicle moves forward?
How many miles on the trans? Any recent repair work on the trans?
Old 01-09-2012, 08:52 AM
A broken hub on the rear planetary will cause this. Pull the fuse and see if you can get third gear maybe you can move it. You probably should look for used or rebuilt tyranny depending on your budget.
1994 Chevy Suburban K1500 4L60e Transmission Problem rmar2010 Transmission - Rearend 2 11-29-2010 03:08 PM
4L60E transmission problems zeitlerusmc Transmission - Rearend 4 12-14-2007 11:48 AM
4l60E transmission problems Tweek Transmission - Rearend 0 08-02-2006 02:52 PM
4L60E transmission problems BICHN69 Transmission - Rearend 6 03-26-2005 11:32 AM
4L60E transmission problems BICHN69 Engine 1 08-14-2004 11:23 PM
