1995 350 valve springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2007, 09:25 AM
I have a 1995 350 out of a 3/4 ton truck with 3/8 valve stems.It has a 480 lift cam ,will I have problems with the springs and valve seals,thanks.
Old 06-04-2007, 09:50 AM
DoubleVision's Avatar
You should always run the matched springs with the cam. Stock springs on a bigger cam can and will lead to spring failure. If you want to change springs you can do so with the heads still on by using either small rope coiled in the cylinder and the piston brought up in the bore until it compresses the rope and holds the valves, or you can use pressurized air through the spark plug hole. If you wish to do so then you may as well replace the valve seals also.
Old 06-04-2007, 06:31 PM
check for coil bind, you need like .060" of freespace before coilbind, 3/8" valvestems?-I thought all SB chevs used 11/32". The older motors without valve rotators could easily run .480 lift on a stock spring.
Old 06-04-2007, 07:40 PM
BOBCRMAN@aol.com's Avatar
HD truck SBC motors have 3/8" exhaust valves, rotators and many have hardened exh seats. Not the hot setup for a 480 lift cam !
Old 06-04-2007, 10:18 PM
383silverado's Avatar
look into comp cams springs part # 986-16
i have 480 in 488 ex cam and these are the springs they recommended
97 silverado 3/4 350 3/8 valve stem
changing valve springs on car? noah55 Engine 6 05-30-2007 08:47 PM
replacing valve springs stfinney Engine 8 09-06-2003 11:46 PM
valve springs juxtoposed Engine 2 07-28-2003 12:45 AM
Valve Springs GearHead69 Engine 5 07-19-2003 12:00 PM
valve springs jeff germano Engine 5 10-28-2002 06:33 PM
