Thread Tools Search this Thread share on Facebook
  #1
Old 01-21-2012, 06:50 AM
finlayson finlayson is offline
1995 chevy 2o van 4.3 6 cyl
trying to set the timing with no TDC mark .also my oil was very thick and dirty we just had 3 days of minus 8 degree weather so would that be why the oil was so thick
Register now (free) or login to remove ads
Old 02-17-2012, 05:58 PM
ChadGresham ChadGresham is offline
Supporter of the 4.3 liter V6
I set the timing on my '86 4.3 liter all the time by listening to the motor. Loosen up the clamp and turn it to the right till it starts to run bad, then turn it to the left till it starts to run bad, then just center between those two and she's pretty well timed. As you drive, listen for spark knock and if you hear it, just back off the timing some more. Also dirty thick oil sounds like its not been changed in a while. Change oil and filter
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "1995 chevy 2o van 4.3 6 cyl"
ThreadThread StarterForumRepliesLast Post
383 stroker in 1995 chevy 4x4?????PRS3Engine1109-26-2011 11:44 AM
Putting a 72' chevy 350 into 1995 chevy silverado that has a 4l80e transWillbee26Transmission - Rearend303-28-2010 10:40 PM
1995 chevy capricecapriderEngine401-08-2010 11:22 PM
T-56 to a PRE 1995 chevy motor?carbobTransmission - Rearend703-07-2007 04:06 PM
Box from a 1995 chevy on an 85 silverado?85silveradoBody - Exterior004-13-2006 11:20 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
