1995 Chevy k-2500 Specialty tech question??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2010, 05:51 PM
rbp rbp is offline
Hi dudes, I have a question regarding the symptoms of my transmission. I have a 1995 chevy k2500. About 8 months ago, I replaced the 2/3 shift solenoid (b) because it was faulty and got picked up by the computer (by the way I replaced both brand new from GM). The symptom was from the shifting from 2 to 3 sometimes it shifts without a problem, but sometimes it didn't shift. To make it shift, I turned off the truck, waited for a few seconds, and restarted it and it shifted without problems. The problem got corrected when I replaced the solenoids. Now it's doing it again. What can be causing this problem? One of my friends said the computer ECU and I said sticking valve. Any hints or ideas???
Old 01-29-2010, 07:21 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
What is the mileage on this vehicle trans?
has it been rebuilt or only the repair you mention?
Has the PCM been scanned with a proper scanner (NOT code reader) that can read code history and watch live data stream as the vehicle is driven?
Old 01-29-2010, 07:57 PM
rbp rbp is offline
the tranny has around 50K the truck 305K! same engine same computer... and no I haven't scanned it. Started acting up just yesterday... I have problaby a long weekend ahead of me. But any ideas will be helpful before I start removing valve body, valves, sensors, computer and R&R of tranny! thanks for ya'll help!
Old 01-29-2010, 09:56 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I gave you an idea to diagnose the problem. Scan the system as it operates in a live data stream. You watch what the PCM is commanding the trans to do and see If the trans responds correctly.
Why would you remove parts when you have no idea what or where to look? It is like a surgeon opening a human without a look see inside via x-ray or cat-scans to have an idea of where to look.
If the trans refuses to shift at certain times... then after you cycle the ignition key to off , then a re-start ... this resets the PCM. There may be a soft code set if the Check engine Lite was not illuminated.... the check engine lite indicates a hard DTC was set
The problem may not be inside the trans. Something that sets a code where the trans is affected does not have to be inside the trans.
You could have a charging - electrical system problem cause this
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 07:57 PM
1995 chevy 1500 4l60e stenichs Transmission - Rearend 2 05-10-2009 02:52 AM
Chevy 10 bolt front end question Magikal Transmission - Rearend 1 12-09-2007 02:00 PM
Chevy Inline six question 40chevy Engine 10 05-03-2006 05:16 PM
56' Chevy Rear Bumper Question maxie56 Body - Exterior 2 05-25-2005 10:11 AM
