Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1995 chevy running rough
Old 05-24-2012, 03:02 PM
1932bantam 1932bantam is offline
I have a 1995 chevy 1/2 ton 350 . just isn't running right, sometimes idles rough, got to feather throttle to take off .no power seems like nothing there in the midrange, wants to die at idle , hesitates and bucks on acceleration. I have rebuilt throttle body put in throttle position sensor , idle control sensor tested map ,new exhaust and o2 sensor ,plugs cap rotor .run a vacuum test fluctuates rapidly between 15 and 18 , also sprayed around intake for v leaks . pulled each plug wire with running seemed like they were all hitting but when I did pull the plug wire off dist cap it makes the coil wire arc to the coil/ does it on every one i don't no if this is normal or not. thanks also have replaced fuel filter
