1995 chevy running rough - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 05-24-2012, 03:02 PM
I have a 1995 chevy 1/2 ton 350 . just isn't running right, sometimes idles rough, got to feather throttle to take off .no power seems like nothing there in the midrange, wants to die at idle , hesitates and bucks on acceleration. I have rebuilt throttle body put in throttle position sensor , idle control sensor tested map ,new exhaust and o2 sensor ,plugs cap rotor .run a vacuum test fluctuates rapidly between 15 and 18 , also sprayed around intake for v leaks . pulled each plug wire with running seemed like they were all hitting but when I did pull the plug wire off dist cap it makes the coil wire arc to the coil/ does it on every one i don't no if this is normal or not. thanks also have replaced fuel filter
Old 05-24-2012, 06:26 PM
LATECH's Avatar
Sounds like a weak fuel pump. Perform a fuel pressure test.
vortec engines like about 62 PSI while running at Idle.Just a few pounds lower than spec can result in poor driveability.
Fact is stranger than Fiction
Old 05-25-2012, 08:46 AM
1995 chevy throttle body--9-13 psi
Old 05-25-2012, 05:45 PM
LATECH's Avatar
Sounds like time to do a compression test. , then check for broken valve springs.
Old 05-26-2012, 05:34 AM
I think your right.
Recent Modern Electronic Engines posts with photos
rough running 350 chevy engine jimjoe Engine 2 08-26-2011 05:58 PM
chevy 350 running rough jak327 Engine 5 03-27-2011 12:32 PM
Chevy 350 running rough at idle The Raven Engine 3 01-07-2010 03:54 PM
Chevy 235 missing/running rough countryboytn Engine 15 09-30-2009 09:55 PM
chevy 4.3l help-detonation, running rough briansansone Engine 4 03-20-2007 07:14 PM
