1995 Chevy S-10 2.2l 350 swap ?'s - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2006, 02:20 PM
I was just looking for any information as to approach this project, any knowledge, tips or suggestions would be highly appreciated. By the way it is a 1995 Chevy S-10, standard cab, 2.2L 4-cyl eng., 5 speed manual trans. 2 wheel drive. Again any info would be appreciated.
Old 03-22-2006, 03:32 PM
Wiki Edits: 31
We just had 1 of these come through the shop, head gasket blew. is the 5spd a tremec TK0 5spd, if so, it can be bolted to the 350, SBC into an S10 is not uncommon, and there are kits for it.
Old 03-22-2006, 04:04 PM
Banned
The tranny can be bolted up to it, but be easy on her- its not meant to take the torque of the 350. If you insist on keeping it consider a 283.
Old 03-22-2006, 04:20 PM
406 ss monte's Avatar
eat a beaver, save a tree
the 2.2L bellhousing is differant then a small block chevy's. from what i'm told, onlt the 4.3L has the same bolt pattern.
i've got a 94 that i'm starting on myself. 2.2L 5 speed, going to a 350 & automatic trans.
http://www.s10forum.com/forum
Old 03-22-2006, 04:43 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
Mine is a 94 that had a 2.2 with an automatic.
Here are some pics.
Steve
ID:	11075   Click image for larger version
Name:	Fuel tank fix 1.JPG
ID:	11077   Click image for larger version
Name:	S10 pics 007 cab up.JPG
ID:	11078   Click image for larger version
Name:	S10 pics 001.JPG
ID:	11079   Click image for larger version
Chevy TBI unit on Olds 350 in S-10 M&M CUSTOM Modern Electronic Engines 13 12-18-2011 11:28 AM
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
700r4 Swap to a Turbo 350 humanVr4 Transmission - Rearend 23 08-02-2004 07:48 AM
Engine swap 305 olds to a 350 chevy morbidmike Engine 6 10-19-2003 11:33 AM
A few ?'s bout a chevrolet 350 engine Nos Engine 11 04-20-2003 07:55 PM
