Thread Tools Search this Thread share on Facebook
  #1
Old 05-11-2009, 09:03 PM
CamaroHunter78's Avatar
CamaroHunter78 CamaroHunter78 is offline
JD Custom Muscle Car Concepts
1995 chevy S10 4.3 non-Vortec running bad under load?
I have a 1995 chevy S10 4.3L V6 non-Vortec TBI.
and it's been running ruff/kinda misfiring when you accelerate or drive it up hill and I don't now whats wrong?
I've replaced the
fuel filter,
injectors,
cap and rotor,
and the ignition coil.
and it still does the same thing!!!
thanks in advanced for the help!
Register now (free) or login to remove ads
Old 05-11-2009, 09:11 PM
fast68's Avatar
fast68 fast68 is offline
likes chevy trucks & boobies
can you have the module tested ? also do a fuel pressure test and see what numbers you get and let us know ?
cap and rotor are usually the culprits on the 4.3L
pop the hood at night while its running and try to see if any of the spark wires are leaking voltage youll see a spark if there is. if one or more are leaking then it will cause some bad running and loss of power like this and it oftens happens mainly under load i have found over the years of working on vehicles for ppl at the shop.
also what plugs you running ?
hopefully ac delco cr43ts
i have a 91 with the vin Z 4.3L same as yours it has 196k on it running strong driven every day extremely reliable
Old 05-12-2009, 12:24 AM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
Socially Unsociable
You`ll also want to check it for vacuum leaks. Is the service engine soon light on? if so have the codes checked.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "1995 chevy S10 4.3 non-Vortec running bad under load?"
ThreadThread StarterForumRepliesLast Post
the history of chevy v8'ssavman1Hotrodders' Lounge4303-02-2012 06:57 PM
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'EngineOldsmolac911Hotrodders' Lounge5001-12-2011 10:00 PM
chevy 4.3 modschevota11secondsEngine608-19-2004 08:50 PM
chevy 2.5L just not running too welldukin-it-outEngine309-23-2003 03:27 PM
Wiring harness for 4.3 vortecrdhe3900Electrical107-08-2003 09:49 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
