Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1995 chevy s10 blazer 4x4 v6 trans problems
Old 11-26-2007, 06:39 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by SonnyFaust
It has 207,000 miles on it. i just changed the trans fluid on it about 2,000 miles ago. It will move forward(with the fuse out)in OD and D but it is in 3rd gear when it does it will not move forward in 1st or 2nd. It wont move forward in any gear with the fuse in. Also when i start it and let it run for a few minutes it will make like a grinding sound regardless of what gear it is in and when i rev it up it gets louder.
Pull the trans out for a proper rebuild...
