Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 1995 chevy s10 blazer 4x4 v6 trans problems
Old 11-27-2007, 04:52 AM
cook67 cook67 is offline
you have planetary failure It goes forward with the fuse out because you only have 3rd gear the solinoids need voltage to acheave different gears in 3rd they are both powered off. in 3rd you have no gear reduction that why its called drive, its direct drive. your forward sprag works because if you put it in manual 3rd 2nd or first the overun clutches hold the sprag, yours doesn't different problem at any rate you need an overhaul
